Oil filter housings >
Oil filter housings
Oil filter housings
Old 03-04-2011 | 06:50 AM
Default Oil filter housings
I'm looking for 3 oil filter housings like in the photos below. also 1 single and 1 double SS transom mount water pickups. Attached Images. Would anyone have a part number for this?
ken sampson is offline
Old 05-13-2011 | 02:39 PM
I found my pick ups. Im still looking for the oil filter housings.
I can also use other types as look as they bolt to the back side of the head. Ken
Old 05-13-2011 | 09:07 PM
STRAIGHTPRIORITY's Avatar
i have two like you have pictured. that mount on the heads.
STRAIGHTPRIORITY is offline
Old 05-20-2011 | 01:04 PM
I'm still looking for one more but will look at any head mount type. Thanks
Old 05-22-2011 | 06:28 AM
ballon78's Avatar
Those are hp500 thermostats, you will have to run a set of the same if you want your oil temps the same, good idea to replace thermostat inside, they are cheap. bammarine.com has the part number of thermostat housing.....
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
