Where is the 90amp fuse on Mercruiser
Like an idiot, I accidentally reversed the polarity when I was putting a battery in my boat. I think I may have blown that 90amp fuse. (according to what I read). I have a Mercruiser 350 EFI... does anyone know where this mysterious 90amp fuse located? I can't find it.
#8 in this picture is the thingamajig you're looking for
the starter is at the r/h side rear of the engine
http://www.mercruiserparts.com/Show_...ER+%28MANDO%29
Check for 12v power at the orange power wire on the backside of the Alternator. If no power there, then there's a good chance the fuse is blown if everything else is in normal working order.
This image should help give you a better idea of the starter fuse,
Looks like I blew the fuse. How do I get at the starter motor 90 amp fuse. Starter motor is on bottom of engine, facing aft, starboard side and buried underneath fuel intake hose and starboard side plywood support.
Ya remove whatever's in yer way of gettin' to whatever yer tryin' to fix,......
Just like any other boat,........ or car,.......... or truck,.......... or anything else,.........
Yes the 90 amp fuse is still on the starter. Item number 8, Genuine Mercury & Mercruiser parts. Starter Motor
