Baja Tachs
You know, I am not sure of the brand. They have a white background and say Baja on them. Boat is under cover so I can't look for manufacturer. I'll have to check in the Spring but I want to say they have gariff on them.
Livorsi can fix them, but what are they doing that makes you think they aren't working correctly?
I've seen my share of guys who think their tacks are broken when all it turns out to be is spark plug wires laid too close to the tach signal wire on the distributor.
Highly unlikely that BOTH tachs are internally malfunctioning at the same time. You most likely have a wiring issue. Start looking for loose grounds and check the igntion kill switch. Both tachs go thru there.
