Oil Filter Questions
I've used the K&N 3002 or the Napa Gold 1060 forever. I just built new engines and wanted to get an even larger Napa filter so I considered the Napa 1794 (a few OSO members run these) But after researching it, I dont want to run he 1794 since it doesnt have an anti drain back valve. When you run it inverted in a marine remote filter, it drains when you shut it off.... so when the engine starts, you have to fill that puppy and the engine presumably runs dry even longer (its about a 1.5 to 2 qt filter)
Should I just stick with what is proven with a K&N 3002 or the Napa Gold 1060 or is their a benefit to the 2 quart filter? Does a 2 qt filter exist with an anti drain back?
What's the benefit to having a larger capacity oil filter? The only real benefit that I see is that it would have a larger element. I don't see why holding a volume would matter, as it isn't in an area that is part of the pickup or supply for the pump. Maybe it would lower the oil temperature having more oil in the system, or maybe the larger filter would act as a helper to the oil cooler?
I'm not saying that there isn't a benefit to running a larger capacity filter, I'm just trying to see where that benefit is.
Kieth:
In your warm water temperatures I would hope and recommend that you concentrate on a bigger oil cooler and don't worry about the size of the filter as the 1060 is plenty big enough to handle the filtering of your engines oil. Its keeping the oil at a good constant temperature around 180-230 degrees under most loads that will do the most to benefit your new engines.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Kieth:
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Would not a larger oil filter help in volume flow?
