Sea water pump conversion
Has anyone changed over a gen V water pump bracket with a old style Mark IV adjustable bracket? I no longer use the mechanical fuel pump, just trying to eliminate the idler pulley. I ordered a stainless one from Dennis Moores website. I can cut a section out of it to make it mount on the pump but I am having troubles with belt allinement. It seems like the pulleys are in a different position on the shaft. Almost seems like I need to install the old style pulley on the pump. Here is the one I just recieved. http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
I am not sure but I believe that you would need to change the whole pump because the "clamp" style bracket goes to the long "snount" pump and it is machined to accept the clamp style bracket. Rookie did a thread ahile back were he rebuilt his pump and had removed the mechanical fuel pump and plced a cover over the hole where the fuel pump went.
Here's the old clamp style.
http://www.perfprotech.com/store/ass....aspx#assembly
