Adjusting Throttle Linkage 454 Mpi
Could you guys help me. I have a buddy that has 454 MPi's and needs to adjust the throttle linkages. The guy he bought he boat from had them turned down so it will only turn 4100 RPM's. Is it as simple as backing off that little nut then threading more cable out? Thanks.
That's what the guy said. I'm cluless on mpi.
Did you mistype here or did you mean to say "is opening all the way" and if so what do you mean? thought you wanted it open at WOT.
Its a 98 29 outlaw with 23p mirage + props. mpi's should turn 4600, right? and with this small of a prop it should hit that easy.
If the throttle body is opening all the way, the boat is not going to run right anytime you push it to WOT.
Here is an easy way to check MPI motors for full throttle. Take off the flame arrestor, it is held on by a couple of small torx screws ( I think t-15) . With the engine off, put the stcks into full throttle position and look inot the throttle bodies. The butterflies should be wide open.
If you are ONLY adjusting the cables' length of travel to get full throttle, then it will not effect the t.p.s. setting. Just don't mess around with the minimum air adjustment. That controls the angle of the butterflies at idle, it will change the t.p.s. settings along with a host of other problems you will encounter.
