Bravo 3 to Bravo 1 conversion question >
Old 03-16-2011 | 11:35 AM
Default Bravo 3 to Bravo 1 conversion question
Is it posible to put b1 lower on b3 upper? Can you install b1 on b3 transom assy? Dumb question i know! Thanks
Jason
jason35 is offline
Old 03-16-2011 | 12:13 PM
yes
JaayTeee is offline
Old 03-16-2011 | 12:19 PM
All Bravo uppers and transom assemblies are the same Yes you can mix and match.
vinzimarine is offline
Old 03-16-2011 | 01:21 PM
Thanks! Upgrading engine for more power and was wanting to get away from the b3 for more prop picks! Thanks again!
Jason
jason35 is offline
Old 03-16-2011 | 01:29 PM
Knot 4 Me's Avatar
Are you going to sell the Bravo III lower?
Knot 4 Me is offline
Old 03-16-2011 | 01:56 PM
Not yet! problly goin to be this winter before i do anything. Just doin some leg work now!
Jason
jason35 is offline
Old 03-16-2011 | 02:32 PM
t500hps's Avatar
21 and 42 footers
Be aware of gear ratio issues......A BIII 2.0 is a 1.50 BI. You may have a 1.81 or 2.2 BIII (1.36 or 1.65 BI)
t500hps is offline
Old 03-16-2011 | 04:22 PM
My b3 2.0 so i will need to find a 1.50 b1 lower?
jason35 is offline
Old 03-16-2011 | 06:49 PM
t500hps's Avatar
21 and 42 footers
No.....any lower will work (gear ratio in upper). For determining the prop you'll have a 1.50 complete BI.
t500hps is offline
Old 03-17-2011 | 08:41 AM
Be aware that there was a generation of BIII drives, that had an upper that was a bit different. The part above the cavitation plate extended out, the full length of the cavitation plate. I have only seen this drive a few times, so I don't know what year they are form. But the BI should bolt with the drives that looks like the one on the left.
http://www.go-fast.com/bravo_3.htm
A.O. Razor is offline
