2007 Chevy 2500 tires
Old 03-16-2011 | 08:59 PM
Default 2007 Chevy 2500 tires
I recently replaced the tires on my truck with goodyear wrangler silent armor prograde. I have noticed that the rubber is very soft and perform terribly on the high highway. Truck is all over the road. Thinking the truck was the problem, had the pitman arm, inner tie rods, and steering stabilzer replaced. Truck is still wandering allover the road. Has anyone else used these tires and experienced that same results?
Donzi Andy is offline
Old 03-16-2011 | 11:19 PM
I use Toyo ATs. Love them almost as much as I liked my Dueller AT's. Can not get the Bridgestone Dueller AT's in 20s, hence the Toyos. I have a 2008 Silverado 2500hd diesel with an extra 100hp and 200 ft lb of torque. Hard on back tires...
Rick
TahoeRick is offline
Old 03-16-2011 | 11:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yep, it's the tires. They suck.
I have brand new Goodyear Wrangler HTs on my Ford Dually at the moment. I bought them because the wheels/tires that I want (19.5s) are not available yet. They are the exact tires that came on my Myco trailer, and I plan on switching them over to my trailer when I get the 19.5" setup.
I can't stand driving on them. The rubber is way too soft and the non-interlocking lugs provide a very loose ride.
They are GREAT trailer tires, but they suck as truck tires. I'll never buy another Goodyear product for a car/truck. But I will run them on my Myco boat trailer.
I should have learned the first time I bought Goodyears for my Tahoe years ago. I took them back the next day as well--terrible.
Sydwayz is offline
Old 03-16-2011 | 11:26 PM
Wobble's Avatar
SORE MEMBER
I am running cooper atr's on mine. they dont handle all the torque as well as the Yokohama's (more wheelspin)I had before but otherwise are good on and off the road
Wobble is offline
Old 03-16-2011 | 11:43 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I ran Cooper A/Ts on my 2500 Avalanche and liked them. I ran them on 16x8 wheels on that truck which drastically improved the handling of that truck vs. the factory 16x6.5" wheels.
I later went to 17x8 wheels on the same truck with BFG Rugged Trail E-rated tires which was also a great setup; especially towing.
Swapping out of the the bicycle-narrow wheels that GM installs from the factory to 8" or 9" wide wheels greatly improves the handling of those trucks.
Sydwayz is offline
Old 03-17-2011 | 04:02 PM
I have a 250sd ford with 20 inch toyo open country at , great tires . all tires for towing should be load range E .
tim brown is offline
Old 03-17-2011 | 04:04 PM
OldSchool's Avatar
We call 'em Pizza cutters.
OldSchool is online now
Old 03-18-2011 | 05:55 AM
what load range ?? 2500's should be E's if you go down it sucks..tried it once on my 2500..took them right back off...heard now it's illegal for a tire shop to go down in load range rating..
ezstriper is offline
Old 03-18-2011 | 06:29 AM
I run the Bridgestone Dueller AT's on my '07 Silverado HD and love them. Great all around tire.
08 fastech 292 is offline
Old 03-18-2011 | 08:43 AM
Fountain4402's Avatar
I got the load range E ones if you went anything less than that than you made a mistake. I have the 18 IN Good year SA's and they work good. All winter up in NY hardly ever had in in 4WD. I dont get drift or anything.
Fountain4402 is offline
