"All American Drive Services" Max Mod Series >
Old 03-19-2011 | 11:08 PM
Default "All American Drive Services" Max Mod Series
Anyone every had any dealings with these drives, the Max Mod and the Max Mod Extreme? Do they hold up?
http://www.allamericandriveservice.c...rformance.html
Brad
598 Formula is offline
Old 03-19-2011 | 11:16 PM
cougarman's Avatar
Brad
Good outfit,............friend has had work done with them several times and always had RAVE reviews about there work quality and service.
Jon
cougarman is offline
Old 03-19-2011 | 11:19 PM
Jon
Did he have the Max Mod drive, or did they repair the drives he has.
Brad
Old 03-19-2011 | 11:25 PM
cougarman's Avatar
Not sure,..............he asked them to build it to hold a 1000hp in an Eliminator,........not sure what internals he went with,...but was a happy camper.
Jon
Old 03-19-2011 | 11:30 PM
If I am reading right, a drive that will handle 750hp, for a little over 9k, with a 2 year warranty....Thats not sounding to bad right now!!lol
Just want to see if anyone has had luck with the drives before I try one.
Brad
Old 03-19-2011 | 11:36 PM
cougarman's Avatar
The owner is also a Pilot,....met him a few times and he is pretty darn fussy about his planes and his maintance program. Third generation pilot......................
Guess it seems to also be a reflection of his work with the drives to
very particular,...very regimented ............
Good qualitys to find now days in the business world.
Jon
Old 03-20-2011 | 03:27 AM
While the guy may be a fantastic drive guy, and have perfect setup on every drive he builds, nothing is going to make XR gears live very long behind 750hp or more other than luck and a limp throttle hand. The problems with these gears arent due to the case or setup in the majority of failures, they are due to the terrible quality control from Mercury. Until someone builds a better gear for the Bravo setup, plan on rebuilds when running the kind of power you are going to run.
Philm is offline
Old 03-20-2011 | 04:31 AM
Does the SCX use XR gears?
Brad
Old 03-20-2011 | 10:33 AM
Mr Gadgets's Avatar
Charter Member #601
No the SCX has it own gears that are much larger than XR..
Mr Gadgets is offline
Old 03-22-2011 | 09:08 AM
For a little more Id go Imco but when I talked with them the 2 year unconditional warranty was very attractive.
ICDEDPPL is offline
