what thermostat >
what thermostat
what thermostat
Old 03-20-2011 | 07:17 PM
Default what thermostat
got a 350 merc. in my 23xl wellcraft nova. calls for a 142 if runnig wide open. an 160 if crusizing my questions is what one should I run and how big a difference between the 2. I do mostly crusing, some wot. Im looking an changing over to a edelbrock perfomer rmp intake.
ctbs99xc is offline
Old 03-20-2011 | 07:55 PM
All the carb engines came with the 140 deg when they changed to fuel injection they started using 160 deg. The actual temp on the gage may vary.
jeffswav is offline
Old 03-20-2011 | 09:45 PM
its qudrajet 4 barrel so i guess ill run 142. i had a 160 in there as of last year.
ctbs99xc is offline
Old 03-20-2011 | 10:26 PM
Was your alarm going off. When I intalled my aftermarket MPI kit I started using a 160 deg therm. My alarm kept going off for the temp being too high, so I installed a temp switch from the 454 Mag MPI engine.
jeffswav is offline
Old 03-21-2011 | 07:58 PM
no it always ran around 160. only if i ran wot for 20mins it would move up to 165 to 170.
ctbs99xc is offline
