Cam didnt make it!
Have carbeurated stock 502 mag. 242LS Formula Use for cruising mostly, real heavy boat I need a lot of torgue to plane looking if anyone has figured optimum set up, lift,duration,type, preferences like good speed but really not looking for excess. Just a killer idle. Should I be considering changing over from flat tappet to roller? What are benefits...cons I also if it matters am presently running manifolds thru hull due to headers DNFed in spring planning on new ones but due to needing a new top end will probably have to wait
What will I be expecting for Max output without pushing the envelope?
Thanks, Rocket
What will I be expecting for Max output without pushing the envelope?Thanks, Rocket
I have an 87 242 LS.
When I first removed the 454/330 and alpha/1.32, I replaced it with a 502/bravo/1.5.
It did 57 mph on a good day. With the HP 500 it did 70 mph on a good day.
I used Chevy head 10101137. Large oval port with lots of work done.
Weiand Team G single plane, port matched to heads.
800 Holley carb.
Cam was an HP500 cam. Crane # 169611. Specs are 222/230 .576/598 110 lsa 105 icl.
With about 9.5:1 it made a little over 500hp.
I used a 23 mirage and topped out at 5200 rpm.
Ps. I'm now Pro Charged with Merlin heads bigger Crane cam and around 900hp. Approx 95 mph.
DAVE
800 Holley carb.
DAVE
BajaRunner
13
02-07-2014 08:32 AM
