Prop help
Old 03-30-2011 | 09:14 PM
Default Prop help
I am looking at props for my new (new to me) boat. Its a 1999 Warlock openclass 27' and has a 502 magnum MPI. I don't have a prop to start with Thats why I am asking. I would like one prop for decent low end to hopefully drag some tubes and another for top end. I have looked at serval prop calculators but the more I look the more confussing it gets. I was looking at some 23 pitched props and noticed they have different diameters (13 1/2x 23p, 14 1/2x 23p and 15 1/2x 23p). Which is the corect diameter or does it matter?
The other prop size I have been looking is 25p-28p.
What direction should I go???
Thanks for any input!!
hemi2001 is offline
Old 03-30-2011 | 10:04 PM
I run a 28p (15 1/4) Bravo stainless in my 28 eagle HP500 for going fast. A 26 when I'm hauling everyone around. I would probably try a 24 or 26. Definitely 15 1/4, no smaller on the diameter.
Eliminator28 is offline
Old 03-30-2011 | 10:12 PM
Thanks!
hemi2001 is offline
Old 03-31-2011 | 01:31 AM
Assuming you have a 1.5 ratio drive, I would start with a 24" Bravo 4 blade. Contact BBlades and use their test program.
Really, that boat is not meant for tubing behind. I doubt it will even stay on plane below 25mph.
Griff is offline
Old 03-31-2011 | 08:29 AM
+1
Def contact BBlades. They helped me out tremendously on my Baja 278 prop choice.
Baja 278 is offline
