Re-coating bilge >
Re-coating bilge
Re-coating bilge
Old 04-02-2011 | 09:57 AM
Courtholl's Avatar
Default Re-coating bilge
While my engine is out of the boat, I want to re-coat the bilge. It looks like they used an interlux product last, as the bilge is grey. I would redo the entire bilge, but am not taking out all of the hardware, etc., so I am only going to touch it up and keep it grey.
I am looking at the two interlux products: Bilgekote and interprotect 2000E. Any recs on which one might be the best option.
Courtholl is offline
Old 04-02-2011 | 02:56 PM
STRAIGHTPRIORITY's Avatar
I use awlgrip... more expensive but much more durable... u can roll and brush and it levels out...
carb cleaner will remove interlux... not a fan
STRAIGHTPRIORITY is offline
Old 04-03-2011 | 05:31 PM
Elite Marine's Avatar
Awl Grip - Snow White is what Joe and Pepe use! Go with the best!
Elite Marine is offline
Old 04-05-2011 | 07:48 PM
How about Bilge Coat ?
Green Eyes is offline
Old 04-05-2011 | 07:56 PM
awl grip is the most durable.
easy to apply.
easiest to clean.
Old 04-05-2011 | 08:29 PM
socalstone's Avatar
Awl Grip makes a ton of products - which one is best for bilge?
socalstone is offline
Old 04-05-2011 | 08:37 PM
i believe i used the topcoat/basecoat with a brush converter (levels out)
i will double check tomorrow
Old 04-06-2011 | 05:56 AM
When I had my crankshaft self destruct last June, I had the engine out and took the opportunity to re do the entire Engine Bay.
I have not used Awl Grip and I am sure its terrific, I used Interlux Bilge Cote - to match the grey I blend grey and white to come up with the correct color match.
Turned out awesome, got rid of alot of cosmetic stuff that used to drive me crazy....and took care of some other random items while I was in there.
Also added a Battery Jumper Box, so we can lift the hatch if the batteries take a dump...fit it under the rear seat...
Overall real happy with the paint....I have used BilgeKote in the Donzi for years... never had an issue. Cleans up great.
Good luck...nothing like a spotless engine bay to show off your hardware.
Danny
Dr. Dan is offline
Old 04-06-2011 | 08:26 PM
Courtholl's Avatar
Which alw grip product is best for the bilge?
Old 04-19-2011 | 01:57 PM
I Line-x My Last Boats Bilge Yellow But All The Hareware Has To Be Removed And Well Sanded And Preped Great Stuff.
LANOUE is offline
