nose cone epoxy >
nose cone epoxy
nose cone epoxy
Old 04-05-2011 | 05:47 PM
Default nose cone epoxy
getting ready to put 2 nose cones on my bravo 1 lowers what is a good epoxy that holds up and any info would be appreciated.
rssteiny is offline
Old 04-05-2011 | 08:04 PM
Nordicflame's Avatar
Sea Goin Poxy Putty for the epoxy and USC All Metal for the filler. Very good luck with this combo.
Nordicflame is offline
Old 04-05-2011 | 09:44 PM
X2 on both products. Make sure to use very aggressive sand paper (24 grit is what I use) to get a good bond to the case.
catman01 is offline
Old 04-06-2011 | 09:05 AM
Do you think that stuff will work for piting (corroded spots)?
TexomaPowerboater is offline
Old 04-06-2011 | 09:31 AM
Has anyone used Marine Trex, and if so, do you need metal filler with it?
My nosecones are installed and on tight, but they're not blended so well. I would like to smooth everything out better, and I was considering using MT. Thoughts or other options are appreciated.
wjb21ndtown is offline
Old 04-06-2011 | 12:17 PM
J-Bonz's Avatar
Thats what I used a while back when I re did a pair of TRS drives. I was happy how the heald up..........
J-Bonz is offline
Old 04-06-2011 | 12:25 PM
Default Fixx
all metal works excellent on the pitting,,nice part is you can finish sand it with 320 and paint over it with just a few coats of zinc primer then paint it shortly after...cant tell its been repaired.
FIXX is offline
Old 04-06-2011 | 02:00 PM
WHERE IS A GOOD PLACE TO GET THESE PRODUCTS
THANKS
rssteiny is offline
Old 06-14-2011 | 11:31 AM
How well does the low water pick up slots line up do you need to do some modifing on that as well and where do i get the epoxy.
Also about how long does it take per drive to do this.
rssteiny is offline
Old 06-14-2011 | 01:03 PM
blue thunder's Avatar
Here's where I got mine to reinstall my bobs nosecone. Works great and packaged as enough for one nosecone. It was around $25.
http://bobsmachine.com/
blue thunder is offline
