Remote oil filter >
Remote oil filter
Remote oil filter
Old 04-07-2011 | 04:50 PM
Default Remote oil filter
I'd like to move the oil filter off of the engine altogether if I can (how far can you go?). If possible, I'd also like the filter to screw UP against the cast piece instead of screwing DOWN onto it. Seems like it would make it alot less messy at oil change time. This is for a 383 small block application. Am I stuck with the Mercury setup?
36Tango is offline
Old 04-07-2011 | 08:45 PM
Registered User
i Think you can put it wherever you want. Mine is on a home made bracket with ss lines. No oem merc setup for me!
Just takes more oil. I probably wouldnt reccomend putting it miles away.
bigblue is offline
Old 04-08-2011 | 07:31 AM
Any pictures?
Baja_man is offline
Old 04-10-2011 | 09:21 AM
I used this kit and mounted it on the transom wall where I could easily access it. Comes with 8' total of hose, you could add more if going further- just remember it increases your oil capacity so be sure to add more when changing the oil.
http://www.summitracing.com/parts/SUM-G4985/
hopper75 is offline
Old 04-10-2011 | 12:14 PM
you want to keep as close as possible, you will lose oil pressure the futher the run is...
ezstriper is offline
Old 04-10-2011 | 12:32 PM
Registered User
Originally Posted by Baja_man
Any pictures?
Im going to go thru my phone and see if anything is on there. If not ill post one when I get in the boat sometime this week. All I have to do is wax and oil change and a little elbow grease!!!! Then Ill be in the water!!!
bigblue is offline
Old 04-10-2011 | 12:37 PM
Registered User
NOTHIN!!! Will snap some and add it when I get em!!!
bigblue is offline
Old 04-10-2011 | 02:00 PM
leave it upside down, it helps filtering....+ no mess if done right. just punch a hole in the top and let it sit over night ...not 1 drop will be left in it for the change next day !
DareDevil is offline
