Torque spec & bolt size for exhaust manifold? >
Old 05-26-2002 | 09:31 AM
djm's Avatar
djm
Default Torque spec & bolt size for exhaust manifold?
I need to tighten my exhaust manifolds but don't have the Merc manual. Does anyone know the correct torque figure for the manifold bolts and the bolt size? Is there a specific sequence? I figured I'd start at the middle and work my way out. Thanks
djm is offline
Old 05-26-2002 | 11:46 AM
Pwrbt33's Avatar
Talking Bolt size and torque.
DJM, you are on the right path by starting in the center and working out. Your exhaust bolts should be 3/8 diameter and they should be torqued to atleast 30 ft pounds. Once you torque one side go to the other and then go back to the first side and do them again. The bolts will actually stretch, thats how a bolt stays tight. Start in the middle and go back and forth till you get to the outside bolts and then you should be ready to go.
Pwrbt33
Offshore Performance
Pwrbt33 is offline
Old 05-26-2002 | 11:59 AM
djm's Avatar
djm
thanks for the reply, do you know what size the head of the bolt is? Looks to be around 12mm if it's even metric. I don't feel like lugging every socket & wrench in the garage over the boat slip.
djm is offline
Old 05-26-2002 | 12:09 PM
Pwrbt33's Avatar
Default Bolt head size.
DJM,
The head size should take a 9/16 socket. If you are using allen head bolts it should be 5/16, if you are using 6 point header bolts it should be 7/16 and last but not least if you are using a 12 point head bolt it should be 3/8. If not any of the above just use lots of super glue and hope for the best !!LOL !!
Pwrbt33
Pwrbt33 is offline
Old 05-26-2002 | 12:22 PM
It's a good idea to retprque after a couple of heat cycles. I am always amazed hope much the bolts loosen up (gasket compresses)
RickR is offline
Old 05-26-2002 | 12:27 PM
djm's Avatar
djm
Thanks for the help!!
djm is offline
PJDiesel
3
03-29-2008 11:49 PM
Shah Mat
0
06-19-2007 11:18 AM
ctadams21
3
03-19-2007 02:41 PM
Rage
41
02-18-2007 09:42 PM
