lorviorsi gps batt change??? >
Old 04-19-2011 | 08:01 AM
Default lorviorsi gps batt change???
Have a gps speedo,lorvirsi,how do you change the batt,was told the top unscrews but can't get it apart any help would be great thnks
park35 is offline
Old 04-19-2011 | 08:06 AM
took mine to a Battery plus store last week and they changed it for me...$3.89 out the door...
or Livorsi will exchange your old antenna for the update antenna for $185.00 + shipping
boatnt is offline
Old 04-19-2011 | 08:07 AM
Dave M's Avatar
Veteran: Navy
Or, throw the antenna in the garbage and wire it to your GPS.
Dave M is offline
Old 04-19-2011 | 08:16 AM
True
boatnt is offline
Old 04-19-2011 | 08:19 AM
Does the unit come apart or is it sealed some how??
park35 is offline
Old 04-19-2011 | 08:23 AM
Registered User
Great topic I just took mine out on Sunday I am pumped to see the replies on this!
Thanks Boatnt I am going to take it in this week I just hope we have on of those stores around us..... I heard they won't even fix the batterys any more at Livorsi
sunsation96 is offline
Old 04-19-2011 | 08:28 AM
I had problems soldering the batt back in, ended up having a terminal loose and had to send it in.
SHAWN DAVIS is offline
Old 04-19-2011 | 08:54 AM
yes the tabs are welded on the battery,batterys plus has a small welder and they weld the tabs back on.
boatnt is offline
Old 04-19-2011 | 11:17 AM
Macklin's Avatar
And weld them on in the correct orientation!
There was a thread on this subject in Technical a while back. One guy said he just super glued a new battery in. I tried that method as it seemed too easy. Didn't work. Soooo, back out it came and went to Batteries Plus for proper repair. If this doesnt work I will wire it to my GPS.
What a PITA design!
Macklin is offline
Old 04-19-2011 | 01:26 PM
blownincome's Avatar
there are 3 small indents in the bottom of the antenna i screwed 3 dry wall screws in a thin piece of wood to line up with them then unscrewed the top
blownincome is offline
