Analog Tach reading off >
Old 04-19-2011 | 10:07 AM
Default Analog Tach reading off
One of my tachs reads off by 500-1000 RPM (low). The Smartcraft displays correct RPM. I've switched tachs and it still reads low on the same side so it's not the tach.
Any thoughts/suggestions? Thanks
ciaoderhead is offline
Old 04-19-2011 | 10:17 AM
If you switched tachs and used the same wiring on the left side, it could be a bad ground.
sleev-les is offline
Old 04-19-2011 | 11:50 AM
I'll check the ground but don't think it's the problem. I also have a Livorsi Data Tach that has dedicated power and ground and shares the tach signal. It also reads the same (low) rpm on the starboard motor.
Something is causing the (analog?) signal to be off on that engine.
Old 04-19-2011 | 12:00 PM
axapowell's Avatar
Where To
The tach needs to be re-calibrated. Call Livorsi.
Dave
axapowell is offline
Old 04-19-2011 | 03:00 PM
Will a bad AGI Box cause this or do they just totally crap out?
Old 04-19-2011 | 03:05 PM
txriverrat2001's Avatar
In my experience - the AGI's just crap out - either in or out - no half a$$
txriverrat2001 is offline
Old 04-19-2011 | 03:36 PM
axapowell's Avatar
Where To
Sorry, I missed that. Maybe the Analog tach is back feeding the data tach. I don't know if there would need to be an isolation between them. Did this just develop, or has it always been this way?
I'd still call Livorsi.
dave
Old 04-19-2011 | 06:20 PM
AGI box will cause that.
redbud35 is offline
Old 04-20-2011 | 05:42 AM
Thanks, ordered one. I'll post how it works out.
Old 05-18-2011 | 10:06 AM
new AGI box fixed it
