Different starter issue than just posted
Got a twin 454s. One engine is fine. When I go to crank the engine its like off and on when the starter kicks on. I have checked all the connections, cleaned the terminals on the starter switched batteries and it still does it. Engine fires right up when starter works. When it doesnt work there isnt any noise click anything. Leads me to beleive its not the starter it may be something else. Any clues
Its too long a run from the ignition switch (voltage drop) to energize the starters solenoid. You'd need huge gage wire and ignition switch. An auxilary contactor (slave) was the right design. The exact same solenoid is on the trim pumps for the same reason.
