Manning trailer paint code
Old 04-21-2011 | 05:04 PM
neva satisfied's Avatar
Default Manning trailer paint code
I have a purple Manning trailer that I need to touch up but am having trouble finding a match for the paint. I called Manning and they informed me that it is a Kustom Kolors paint "Passion Pearl PBC 65" to be exact. Well here is the problem, this particular color is a tri coat color with a white base. This is alot of steps just to touch up a few spots. Has anyone here had any luck matching this color with another paint? Every purple I look at is either too dark, too light, too red, or too blue. Not looking to be spot on but some where close.
neva satisfied is offline
Old 04-21-2011 | 10:17 PM
I would try going to a paint supply house for body shops and have them do a computer match, it will either give a stock color or a formula for a match. I just went through this with my Manning trailer. I have the code, but it's Imron, and even the correct color doesn't match. So i went the computer match route, haven't used it yet, but did a test sample and it looks pretty close. Good luck!
Steve
509 SC is offline
Old 04-22-2011 | 04:44 AM
I stopped at the supply house yesterday and they told me it would be tough to get a computer match on that paint. I glad to know that you were able to do it. That's going to be my next step.
Old 04-22-2011 | 06:02 AM
boatme's Avatar
My guess is your trailer is under a Sunsation
We did alot of trailers back in the day for Joe when I owned Manning The purple was a Kustom color to match the boat purple paint. What is under the purple paint it is a light grey primer then the color is sprayed then the clear coat is added to the process (was very expensive to paint ) Later on we found a paint that was close to the same color with out the 3 step process (Only two step)
You can touch it up with original paint just takes a bit of talent and a bit of build up
boatme is offline
Old 04-22-2011 | 08:42 AM
The passion pearl in not a 3 stage paint you can shoot it straight out of the can. Also it is made by House of Kolor If you are doing just some touch up find a custom paint shop in your area that may just pour you off a little bit of the paint for touch up. I know we keep house of kolor stuff in stock and have sold small amounts to people who are doing touch ups on things like that. But most of those people are local and we did not ship the paint to them. I would hate to see you buy a whole quart of the paint just for touch up unless you want to spray the areas you are ttouching up.
redsled33 is offline
Old 04-24-2011 | 04:35 PM
Thanks everyone. I think I will need to find a better supply house. They gave me this big song and dance about it could not be mixed or applied in any other way. Now that I know I can get it in a spray can I'm going to look more agressively.
Old 05-02-2011 | 12:15 AM
I work for Manning Marine. If you are having a hard time finding paint for it, I think we have a bit left in supply. So if you cant find any, email us at ManningMarine.com and i will see if it is possible to ship you some a a reduced cost.
purplesaurus95 is offline
Old 05-03-2011 | 05:05 AM
Thank you so much for the offer. I have managed to find a quart at my local supply house, and they are eager to get rid of it. I am actually shocked that a trailer manufacturer would use such a high end paint. I was not expecting that.
Old 06-05-2011 | 10:06 PM
Strip Poker 388's Avatar
Rob
Who owns/runs "Manning Trailers" NOW?
Strip Poker 388 is offline
Old 06-05-2011 | 10:13 PM
Ron and Pam Manning. Same as always.
dewayne6243 is online now
