10778C oil pump, which pressure spring? >
Old 04-22-2011 | 10:58 AM
Default 10778C oil pump, which pressure spring?
Which pressure spring are you guys running with these oil pumps? The high pressure one that comes pre-installed or are you swapping out for the lower pressure spring that comes with the pump.
1999 HP500
SmurfOnABoat is offline
Old 04-22-2011 | 11:05 AM
1999 HP500
Use the spring that it comes installed! I'm running the same pump.
endeavour32 is offline
Old 04-22-2011 | 05:14 PM
Boat1 is offline
Old 04-23-2011 | 05:14 AM
Vinny P's Avatar
I hate the winter!!
X2 Have used that pump on a few engines thus far, great pump.
Vinny P is offline
Old 05-05-2011 | 06:47 AM
blue thunder's Avatar
What sort of idle oil pressures are you getting with that pump and the purple (High pressure) spring? I am trying them for the first time this spring and noted on the cut sheet that came with the pumps that these are not recommended for stock applications because the idle pressure will be low. Do you guys see that? I fired my 2 new engines with them and cold idle is 55psi which I am happy with but wonder what hot might be. I guess the anti cavitation grooves these pumps have must bleed of OP at low rpm?
blue thunder is offline
