Compensating for "Hook" with Prop selection? >
Old 05-27-2002 | 07:29 PM
BAD-HABIT's Avatar
Default Compensating for "Hook" with Prop selection?
Since I just found out my baby has almost 1/2 inch of "hook" in her I was wondering if as suggested elsewhere if a prop with more stern lift would be better for a boat with hook? If so what is a good choice for "stern-lift" Also would this explaing why I run about 400 rpm's less that outher boats with similar setups?
"Bad-Habit"
Attached Thumbnails Compensating for "Hook" with Prop selection?-formula1.jpg
BAD-HABIT is offline
Old 05-27-2002 | 09:47 PM
Tinkerer's Avatar
If your boat has a hook it has built in transom lift. In order to make the boat fly you need a prop with bow lift to overcome the built in transom lift. If you remove the hook you may get some porpoising but you get rid of that with tabs. A straight hull will be faster. If you decide to remove the hook do it a little at a time. IF you start to get too much porpoise sand off a little.
Tinkerer is offline
Old 05-27-2002 | 10:12 PM
Pleaes check out replys to "HOOK" thread by "Cuda". --- Jer
jpclear is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
BAD-HABIT
5
07-28-2003 01:31 PM
mikesufka
12-26-2002 11:23 AM
BAD-HABIT
06-05-2002 03:42 PM
