Remote Reservoir On Hydraulic Steering >
Old 04-24-2011 | 08:34 PM
Default Remote Reservoir On Hydraulic Steering
I am installing a dual ram on a single Bravo and was wondering if it is required or just a good idea to run a remote reservoir on the ps pump? The pump is mounted just in front of the cylinder head so it is fairly high. I know certain companys say it's not required and some do. Don't have tons of space to mount one due to the engine hatch but could come up with something if I have to. Any thoughts? Thanks
larose481 is offline
Old 04-25-2011 | 07:21 AM
Dave M's Avatar
Veteran: Navy
My previous boat had a single ram full system and NO reservoir. Never had any issues.
I have ITS on my current boat and no reservoir.
Dave M is offline
Old 04-25-2011 | 08:31 PM
Thanks for the reply. Does anyone else have any input? If I was to run a reservoir, is it better to have one the fills from the bottom from the original cap or dump in the side/top and draw from the bottom?
Old 04-25-2011 | 08:55 PM
I run dual ram full hydraulic and have never had any issues. Had it for 8 years now. I would mount it higher and fill from bottom and top.
GTOFFSHORE is offline
Old 04-26-2011 | 12:47 AM
c_deezy's Avatar
You don't need it. Once the ram(s) are bleed the fluid volume will not increase any more than it did stock from heat.
c_deezy is offline
Old 04-26-2011 | 12:30 PM
Scott's Avatar
Charter Member #30
Same here dual ram and no reservoir with no problems 6+ years
I have Steps & Bubbles!
Scott is offline
Old 04-26-2011 | 07:57 PM
Well I guess I will try and run one without and worst case i will have to add one later. Thanks.
