Need Prop advice >
Need Prop advice
Need Prop advice
Old 04-27-2011 | 01:20 PM
Default Need Prop advice
I have a 26' Sonic Prowler. Weighs about 6000lbs dry. The engine is a bbc 502 with just over 600hp. Looking for a good all around prop that wont be a pig out of the hole but still give me good top end. I want to do 80+ mph.
KOMPLEX1 is offline
Old 04-27-2011 | 01:28 PM
Sydwayz's Avatar
Forum Regulator
Probably start with a 26p 4 Blade B1.
I had the same boat and ran a 24p 4 Blade B1.
You might be able to turn a 28p 4 blade B1.
Stick a post in the Sonic forum to bounce your setup off others.
Sydwayz is offline
Old 04-28-2011 | 12:45 AM
There is no way a 26 ft single screw boat weighs 6000 lbs! If that's true its going to need more than 600 hp to move at 80 mph. Are you sure about the weight?
Powerquest_Baby!! is offline
Old 04-28-2011 | 08:05 AM
Sydwayz's Avatar
Forum Regulator
It's a very heavy boat. Brochure specs of days past were 5050 lbs. (before vacuum bagging was introducted to the Sonic line) I'll bet mine was around 5500 lbs; probably 6000 lbs. when the 102 gallon fuel tank was full. It was 7280 lbs. on trailer with fuel and all of my gear.
Sydwayz is offline
Old 04-28-2011 | 09:08 AM
My mistake. Just looked at the original "window sticker" and the dry weight is 4900lbs "Approx". Not sure where I got 6000lbs from. Mine is undergoing a minor diet. Loosing close to 200lbs with removing silent choice, stock manifolds, and steel heads for aluminum. 200lbs might be optimistic. lol
KOMPLEX1 is offline
