Painting cockpit floor
Old 04-30-2011 | 12:40 PM
bigboat28's Avatar
Default Painting cockpit floor
Is awgrip durable enough to paint a cockpit floor? Or is there something better?
bigboat28 is offline
Old 04-30-2011 | 01:07 PM
I like http://www.durabakcompany.com/ I've used it on many work boats, very durable.. Depends on the look you want..
Duck Diggler is offline
Old 04-30-2011 | 10:03 PM
How does that feel on the bare foot looks like you would get good footing on it but does it hurt your feet?
firehawkcat is offline
Old 05-01-2011 | 09:40 AM
I have not tried it with bare feet, I have only applied it to workboat decks and surfaces. It has rubber suspended particles in the paint and doesn't look like it would be all that bad on the feet, I really like it for its waterproofing properties also and will probably do my fishing boat with the stuff. They also make a smooth version which I have not used yet.
Old 05-01-2011 | 10:23 AM
STRAIGHTPRIORITY's Avatar
awlgrip is very very durable... i have used it on many floors and never even scratched it...
STRAIGHTPRIORITY is offline
Old 05-02-2011 | 02:26 PM
I just did mine with Sea Hawk Tuff stuff primer ( great products) and interlux perfection 2-part paint. It will be finished with Kiwi-grip on top of the perfection for anti-skid purposes and the easy of touch-up.
bigmike253 is offline
Old 05-02-2011 | 04:46 PM
glassdave's Avatar
Neno the mind boggler
a big factor in floor durability is prep. Make sure it is very very well sanded and it doesn't hurt to use an adhesion promoter either
08 OPA High Points Champion
glassdave is offline
Old 05-03-2011 | 08:18 AM
I've never used awlgrip, but have used imron single stage, both with and without flattening agent, rolled / brushed on. I've had great luch with interlux "intergrip" additive on decks - tiny clear plastic spheres that if added to the paint (AFTER adding catalyst) and allowed to soak for a short bit to soak up paint. it gives the paint a nice, even non skid surface that won't discolor, etc... like sand or rubber additives can.
As mentioned above, with propper / meticulous prep, it makes a very durable surface.
a thought, while I wouldn't hesitate to use awlgrip, polyester urethanes like awlgrip aren't quite as hard / durable once the surface is broached (as in after wetsand or wear on it a bit), acrylic urethanes like imron don't have quite as hard an outer surface initially, but do not lose durability when the initial surface is broached... while I've no evidence or first hand experience to say this, imron might be a little better for a cockkpit than awlgrip for this reason.
gelcoat is of course hard to beat in terms of durability... Just sayin...
Hope this is helpful
wtfo is offline
Old 05-07-2011 | 06:33 AM
Indy's Avatar
Member #154
I used this over my Lonseal Lonwave floor in my old PowerPlay after talking to an Interlux rep:
http://www.yachtpaint.com/usa/diy/pr...es/search.aspx
I used the two part Perfection for a glossy look, it looked great and wore well. I wouldn't use the glossy for a flat surface but for a Loncoin or Lonwave it was the right application. It chipped when I dropped an anchor on it but I'm not sure what wouldn't, a quick touch-up and back in business.
Dave is right though, prep like crazy and prime if required. As in any paint job, the easy part is the application, the work is in the prep.
Indy is offline
