Go Back  Offshoreonly.com > Owners Forum > Spectre
spectre 30 w/pm300 trim indicators? >
Old 04-30-2011 | 03:35 PM
northernoffshore's Avatar
Default spectre 30 w/pm300 trim indicators?
What brand of indicators work best on the 300 promaxs. I have a bravo style ones strapped to the ram. Doesn't seem like the cables clear good enough and it sort of a goofy set up? What is every one else using? thanks jay. and here are pics of boat
Attached Thumbnails spectre 30 w/pm300 trim indicators?-dsc02590.jpg   spectre 30 w/pm300 trim indicators?-dsc02586.jpg
northernoffshore is offline
Old 05-01-2011 | 10:05 AM
I have Stainless Marine pop up indicators on mine. The cables might need to be replaced from time to time, but they work fairly well. If you have indicators in your dash already you could probably just get actuators for outboards and hook them up to your indicators.
The installation is not bad except for drilling some bolt holes on the lowest part of the center section of your outboard. If you order actuator parts from stainless marine be sure to tell them you have the offshore bracket. Theres a big difference between the offshore actuators and the fishing engine bracket actuators.
FullAuto9 is offline
Old 05-01-2011 | 01:44 PM
Thanks, I have a gaffrig panel and am going for the stainless marine ones .also going to do the lowers with a puke tank and taylor seal carrier because they are pretty beat up. If you boat was at the cape coral poker run , it looked awesome and motivated me to get this 1. thanks jay.
Old 05-01-2011 | 10:16 PM
we used to rig all the outboard boats with the stainless marine indicators.
obrien is offline
