Anyone have "shoot through" depth meter
You need to get a proper sized hole saw, one that is the same or slightly larger then the "puck". Take the drill out of it and cut through the core untill you hit the fiberglass bottom. Coat the bottom and sides with epoxy and seat the puck in the hole.
Do not forget to dake out the drill or you will have a 1/4 inch hole in the bottom of your boat.
Youll need to dig out the core for it to be accurate.
Uncle Dave
