Water pressure sender >
Old 05-01-2011 | 08:29 PM
Default Water pressure sender
Should the sender be the first thing off the seawater pump or can it be anywhere in the system, ie, behind intercooler, fuel cooler. Raw water cooled system.
osur866 is offline
Old 05-01-2011 | 08:37 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Most are in the block itself
US1 Fountain is offline
Old 05-01-2011 | 08:39 PM
where in the block?
welfare racing is offline
Old 05-01-2011 | 08:50 PM
Many run a small water tube (no sender used) from the intake manifold to the dash gauge. Livorisi's dealers should have parts, tubing, fittings you need.
BenPerfected is offline
Old 05-01-2011 | 08:58 PM
I have one and it's on the PS cooler after the intercooler and fuel cooler and ahead of the oil cooler, question is does it matter where the location is in the system for an accurate reading?
osur866 is offline
Old 05-02-2011 | 01:02 AM
Install it in a port on the intake manifold if you have one. The other option is to install it in one of the block drains. If its installed in a block drain, they tend to clog easily from sand and sediment.
Griff is offline
Old 05-02-2011 | 07:32 AM
Rookie's Avatar
My block drains will clog halfway through one season. I put mine in my intake under my T-stat.
Rookie is offline
Old 05-02-2011 | 08:05 AM
I just replaced my old 1/4" tube pressure gauge with a new livorsi with a 1/16" tube(guessing on size) mech. pressure guage. The old one used a modified block drain fitting and was totally clogged and useless. I'm moving the new one up to the intake manifold.
Thunderstruck27 is offline
