Boat Lift Info..
Old 05-04-2011 | 07:28 AM
Default Boat Lift Info..
I am looking at various boat lifts for my Baja Outlaw. 29' long.
Has anyone used a Sunstream Sunlift? It is a hydraulic boat lift that sits on the lake bottom. The one that the salesman is trying to sell me has a solar powered system. Any feedback on that vs the more standard electrical system?
Any feedback and/or opinions would be appreciated. I use the boat in Lake Erie and it is in a sheltered harbor so waves are not a concern.
Thanks.
baja29sandusky is offline
Old 05-04-2011 | 07:45 AM
Polylift
Donzi Dude is offline
Old 05-04-2011 | 09:21 AM
Sea-Dated's Avatar
Originally Posted by Donzi Dude
Polylift
+1
Sea-Dated is offline
Old 05-04-2011 | 09:45 AM
I have a sunstream 10000lb. lift under a Baja 36 Outlaw. Couldn't be happier with it. Boat weighs 8500 dry so the lift is at max and never had a problem. Get the battery power with a trickle charger if you have access to shorepower otherwise the solar will work as a trickle charger to the supplied battery.
They gave me 2 remotes with the lift. I keep one in boat so I can lower it from the cockpit.
BRET is offline
Old 05-04-2011 | 10:18 AM
Default fixx
Floe,,built to last..
http://www.floeintl.com/docks.asp?pa...icalLifts&sm=4
FIXX is offline
Old 05-04-2011 | 10:29 AM
Bret.
How long have you had your lift? Any problems with it? What do you do in winter to protect it from the ice?
Thanks.
Old 05-04-2011 | 11:11 AM
Originally Posted by baja29sandusky
Bret.
Thanks.
Put it in in '06. Never a problem. I have a crib docks so I have a ice bubbler for winter. I just leave the lift in the down position. Never had a problem.
Even if the bubbler fails the lift is in about 4 ft of water at the shallowest part, so it shouldn't freeze.
Bret
BRET is offline
Old 05-04-2011 | 12:06 PM
BraceYourself's Avatar
Manning Lift... Key fob remote
Attached Thumbnails Boat Lift Info..-img00063-20100508-1007.jpg   Boat Lift Info..-dsc01082.jpg   Boat Lift Info..-dsc01083.jpg
BraceYourself is offline
