caferacer wont crank over with push button ideas??
Looking for some help,caferacer put new power in checked all conections,turn key on on both motors they won't turn over ,if I jump it out at the solenoid they start right up checked the push button switch its gd any ideas thought net safty switch but both bad?
My guess is it is the neutral safety switch. Move the shifter back and forth and find the right spot. Oh and by chance someone didn't hit the breaker switch on the wall on your left going in to the cabin did they? If so push to the up position and fire it up.
Frank how is everthing gd I hope!yes I ck the panel in the cabin and the main breakers,funny thing is it worked before and the problem is with both motors not just one I will keep looking thanks
Make sure you did not tighten the clamps on the Merc plugs to tight. I have seen where the pins will not moake good contact if the plug is too tight. Also check to make sure the starter wiring is correct. Jumper Wire.
ok here we go,ck all grounds,tested push botton switch,moved shifters around still nothing on BOTH motors,is there a in line fuse any where,going to ck net safty switch 2morrow,not easy to get to,thnks for all the input
you have checked the most likely. its always something stupid, my quess the relays mine are mounted above fuel pump, are not grounding besause you painted everything.the relays take power from rocker swith , rocker switch does not go direct to starter selonoid. only fuses I know of are in the little door under the steering wheel
