Go Back  Offshoreonly.com > Owners Forum > Powerplay
transom mounted water pick-ups >
Old 05-05-2011 | 09:31 PM
Default transom mounted water pick-ups
anyone have any experience transom mounted water pick-ups on pp
suggestions apprecaited
MACTIME is offline
Old 05-06-2011 | 05:01 PM
rlj676's Avatar
My water pickup is on my transom, not sure what advice you're looking for?
rlj676 is offline
Old 05-16-2011 | 10:03 PM
how low below the transom are yours and did you notch the hull/transom?
MACTIME is offline
Old 05-17-2011 | 02:21 PM
rlj676's Avatar
No notch, a few inches down off center by half a foot I'd guess. I'm not sure exactly though as the boat's still in storage.
rlj676 is offline
Old 05-17-2011 | 03:43 PM
No notch in mine and its dead on center.
POWERPLAY J is offline
Old 05-17-2011 | 07:39 PM
AIR TIME's Avatar
with a single you want to be outside of the prop, so you don't mess the in coming water to the prop, thats why most twins are center vee there away from the prop. I am setting up my 28 saber that way a few inches from the prop and from the chine since mine both run full lenght of the boat. I will run mine as flush. but its adjustable so I can work with it. Bill at Diamond marine has a great price on them.
AIR TIME is offline
Old 05-17-2011 | 08:12 PM
With your twin, you should mount a double pickup in the center of the V (with no notch)and start with 1/4" hanging below the running surface. Adjust up to lower water pressure.
maverick is offline
Old 05-18-2011 | 09:34 PM
thanks
working on proper height and water pressure now
MACTIME is offline
