steering hub adapter??? Help >
Old 05-06-2011 | 09:03 PM
Default steering hub adapter??? Help
I have the old original tilt steering on my 78 spectra that I am restoring. I like the tilt however what type of adapter do I need to fit modern steering wheels? I just removed the long nut and bolt holding the original one on and there is a square, slightly tappered male post with a hole for the bolt.
I have a couple of steering wheels I purchased off the board.
One is round tapered key type which I would like to use and the other is a std 6 bolt pattern. Regardless is there an adapter for one or the other or both. If I recall the first one mentioned came off a Fountain. The old wheel simply forces me to intall my new seat bases back to far taking up way to much valuable space.
If I had to guess I would say the square shaft is roughly 5/8" and sticks out about 3/4" from the rest of the tilt/steering assm.
Thanks guys,
John
getrdunn is offline
Old 05-06-2011 | 09:09 PM
Can you post a picture i have a square hub that came off my Fountain that had a 3 spoke dune buggy wheel.
tman is offline
Old 05-06-2011 | 09:20 PM
This what I need. Just want to stay as shallow or close to the dash as possible as the assm with the tilt already is out further than I prefer.
http://shopping.rexmar.com/Merchant2...=steeradapt2rg
getrdunn is offline
Old 05-06-2011 | 09:45 PM
jbraun2828's Avatar
I was told they dont make an adapter for a square shaft. Had the same problem with my boat after I bought a new wheel before looking at the old stuff. I ended up puting in a new helm with the tapered key way shaft. I really didnt look to hard for an adapter so maybe the sales guy was full of crap and someone does make one
jbraun2828 is offline
Old 05-06-2011 | 10:23 PM
What about this one?
http://shopping.rexmar.com/Merchant2...teeringhubmisc
getrdunn is offline
Old 05-07-2011 | 07:24 AM
The one i have is for 3 bolts to hold wheel. sorry cound not help.
tman is offline
Old 05-07-2011 | 08:13 AM
gaffric makes them...have one of their new wheels with that hub..
ezstriper is offline
Old 05-07-2011 | 10:53 AM
Thanks,
Will check it out.
getrdunn is offline
Old 05-07-2011 | 11:20 AM
Mbam's Avatar
Offshoreonly Advertiser
That's the classic Mercury Ride Guide setup.
Mbam is offline
Old 05-07-2011 | 11:44 AM
Is this the one you used. The Merc square shaft I have appears to be tappered slightly but assume they are or were pretty much all the same then.
Thanks,
John
getrdunn is offline
