Jcperf
Old 05-07-2011 | 06:00 PM
Thumbs up Jcperf
Turned it to 5300 with a 32P, a full tank of gas, and 3 people. Need to prop it down.Jeff can still throttle. Turn up the volume.
http://youtu.be/Fdp1bcbC6bQ?hd=1
Mastercraft240 is offline
Old 05-07-2011 | 06:14 PM
spazboz's Avatar
Love the sound.
spazboz is offline
Old 05-07-2011 | 06:15 PM
Nice. Glad it worked out.....this time.....
Philm is offline
Old 05-07-2011 | 09:58 PM
Good luck. I have used jeff many times always had great results. He has a pair of my motors now.
sv43BB is offline
Old 05-07-2011 | 11:30 PM
Stormrider's Avatar
JC Performance Engines
Great 1st run.
Are you happy with the speeds?
Btw, does anyone make a bluetooth mic?
That would be slick to have it mounted to the transom.
The audio would be that much better.
Stormrider is offline
Old 05-07-2011 | 11:45 PM
Thumbs up
Sounds Great..!! looks like a great day too....!!
PokerRun388 is offline
Old 05-08-2011 | 12:36 AM
Great 1st run.
We're VERY happy with the speeds. Turning a 32 B1 5300rpm, 86mph with a full tank, 3 190lbs+ people on board, and cruising at 58mph at 3900-4000rpm. With a that same load before the JCPERFORMANCE overhaul, we were only at 78mph. We've only had an increase of 30hp, but we've increased torque somewhere in the 70 range. There is a huge difference. Jeff also replaced the solid cam with a hydraulic cam which should prove to be more user friendly. Jeff has gone over and beyond with me and this motor. I can truthfully say not many engine builders are as honest, forthright, and straight forward.
SV43BB,
Saw your 1075's at the shop today. Looking forward to seeing what it'll do.
Old 05-08-2011 | 01:24 AM
PhantomChaos's Avatar
Sounds aweome and ran good for a couple minutes!! Not sure what you mean though about "not many engine builders are as honest, forthright, and straight forward". How many engine builders have you tried? Teague? Zul? Pfaff?
PhantomChaos is offline
Old 05-08-2011 | 04:56 AM
[QUOTE=Mastercraft240;3397501] Jeff has gone over and beyond with me and this motor. I can truthfully say not many engine builders are as honest, forthright, and straight forward.
I second that he always goes above & beyond & w Zul doing the setup on the dyno Jeff is hard to beat for the price. I do think he weighs more than 190 lbs though !
BBILL1174 is offline
Old 05-08-2011 | 05:03 AM
dykstra's Avatar
Sounds awesome!!
dykstra is offline
