Go Back  Offshoreonly.com > Owners Forum > Powerquest
Trailer brakes >
Trailer brakes
Trailer brakes
Old 05-08-2011 | 02:19 PM
Default Trailer brakes
I am wondering if anybody else has had trouble with there trailer brakes on there powerquest trailers made by r and d trailers? I just overhauled mine so they would work and I cant back up without them locking up and there is not a lockout seloniod on them and no lever to lock it out manually I am thrown for a loop! Any help would be greatful
clayboy is offline
Old 05-08-2011 | 03:27 PM
disc or drum?
if you have disc brakes than you will need to install a back up solenoid...
if you have drum brakes than you might have them too tight...adjust brakes until they drag and then back up 10 clicks.
boatnt is offline
Old 05-08-2011 | 08:40 PM
Cool
Thanks! I have the drum setup and when I rebuilt the system I just cranked the adjusters down tight and then just backed them off a little till the wheel turned they may still be cranked down to tight I will have to crawl under there and try backing them off 10 clicks.
clayboy is offline
