Exhaust Modifications
Old 05-09-2011 | 12:32 AM
Default Exhaust Modifications
I've been looking for some Current USCG regulations about loud exhaust, and have read some state regulations, stating that "cut-outs" are strictly prohibited, for example .. "8. Muffling Devices To reduce noise, motorboat engines must be equipped with factory-installed mufflers, exhaust water manifolds or other effective muffling system. Boaters are prohibited from: • Using cutouts; • Removing mufflers or muffler baffles; • Cutting or punching holes in mufflers; and • Modifying the original muffler or muffling system in away that increases noise level" Oklahoma law.
I've been running 3" strait thru-hulls on my boat, and I've not been questioned, but I've recently built a pretty stout 387 cid stroker for the boat, and have bought 4" thru-hull exhaust with cut-outs that direct the exhaust through a bunch of little holes in the bottom of the pipes ... good or bad ?
Any suggestions ? are they cracking down on the law ?
Where is the USCG regulation stating such info ?
OleRed is offline
Old 05-10-2011 | 12:02 PM
USCG does not have noise regs. Noise regs all vary a little from state to state.
Griff is offline
Old 05-10-2011 | 01:11 PM
Plum_Crazy's Avatar
In my waters, guys are stopped for noise mostly in the no-wake zones. A set of turn-down pipes will keep you out of trouble there. Plus, they actually do limit the noise a little on plane by directing the sound at the water.
These are Gibsons...
Plum_Crazy is offline
Old 05-10-2011 | 02:04 PM
RMPRam's Avatar
Here is what I did to the exhaust on my 38 Cigarette to meet Minnesota DNR noise regulations. It works. Exhaust between the drives and points downward. The only time it was moderately loud was coming on plane from directly behind the boat.
RMPRam is offline
Old 05-10-2011 | 02:14 PM
Coolerman's Avatar
PF Marine
Do you still have the muffler box you made that was going to fill in your notch? That would have been completely silent.
Coolerman is offline
Old 05-10-2011 | 02:19 PM
Underwater kit, by CMI.
I got two set, (for 2 motors)
Should be called "noise B gone".
PARADOX is offline
Old 05-10-2011 | 02:33 PM
Gladhe8er's Avatar
It all depends on where you boat. I assume you are on an Oklahoma lake. Depending on the regulations, cops may or may not be worried about noise.
I have gotten in trouble on Lake George in upstate NY. They have a 90 DB limit 1 meter from your transom. My AT with 525 blows 99 DB's, so I was issued a ticket and kicked off the lake for the weekend. A couple guys I know put CMI clamp-ons on and they are around 90-90.5 DB. If you have the donkey d!cks like a few guys have already posted, they give you a different test. You have to run your boat on plane at a certain speed past the DB meter. I forget what the limit is for that test.
Gladhe8er is offline
Old 05-10-2011 | 11:45 PM
I take my boat to several states, Minnasota, Illinois, Texas, and Akansas, have taken several trips on the Mississippi river and the Arkansas, we have not had any problems in the last two years, but now, there are several people that have been issued tickets, and had to take their boats off the water.
It would be a bad deal to take the boat to one of the shows and not be able to put it in the water, or get a ticket, thats why I'm asking questions, I'm a little concerned about "cut-outs strictly prohibited " in most states, and the only part of the USCG reg's I can find about it is the part that says the boat must meet all the federal and state laws before it will pass one of their inspections.
Thanks for the replies.
OleRed is offline
Old 05-11-2011 | 01:29 AM
Noise regulations are NOT mandated by the USCG. You have to look at each State Law where you boat.
Cut outs means, that you can't have Silent Choice type exhaust or switchable mufflers.
Griff is offline
