Reassembly: 454 Mag Mpi >
Old 05-09-2011 | 08:42 AM
Default Reassembly: 454 Mag Mpi
Hi all,
I am reassembling my 454 mag mpi injector/efi wiring. I have the manual 23 with the schematics, but was wondering if anyone has or could take me a few pics of theirs for reference. I left the harness with the injector plugs on the intake purposely when it went to the machine shop. It came back in a box next to it. Never had a chance to take any reference pics. Any help would be greatly appreciated.
tebo is offline
Old 05-09-2011 | 12:57 PM
Originally Posted by tebo
Hi all,
I have a 1998 454 MPI (385 hp) that I am rebuilding. I took lots of pics during disasembly - I might be able to post those on Snapfish or something similar. Let me know if its the same motor as yours.
dogturd21 is offline
Old 05-09-2011 | 02:50 PM
Yep, same engine as mine. If you could email, I'll post my adress.
Jeremy
tebo is offline
Old 05-10-2011 | 06:04 PM
Default 454 Mpi
Tebo do yourself a favor and throw away the oil cooler and lines.. Buy new. I know 3 people including myself that reused the old ones and lost a main bearing. Not worth it to risk it.
Chris
Blueabyss is offline
Old 06-15-2011 | 09:57 PM
wow, I'm going thru the same process right now and just can't figure out the wiring harness routing. It would be great to have some pics!
Davedog is offline
Old 08-01-2012 | 01:18 PM
Would any pic's still be available to help identify the wiring harness connector to injector order for a 454 mag / mpi?
"Stupid is as stupid does"
low buck is offline
Old 08-01-2012 | 10:55 PM
28Eliminator's Avatar
Here is one from the top. The 2 per cylinder is pretty obvious when you get the wiring harness routed, but not sure how to tell which of the 2 go to each injector. If you notice the white tape on the front wire for each pair, I have them labeled.
http://i1173.photobucket.com/albums/...0/100_0247.jpg
28Eliminator is offline
Old 08-02-2012 | 09:01 AM
28 Eliminator
WOW !
Can't thank you enough for your help. I have been very careful during the tear down, labeling, numbering, etc...
Get another person involved and the practice goes by the wayside.
Thanks again ...
low buck is offline
Old 08-02-2012 | 09:14 AM
Default 454 Mag/Mpi Injector
28 Elim's photo is a god send ...
There is an observation I made, the wires that are exposed between the injector plug and cable wrap are different colors. It looks like they are red / blue on some and red / green on others. Haven't quite developed a pattern, yet.
I'm feeling much better about "reconstructing" the proper connecter sequence.
I'm open and thankful for ant other input.
low buck is offline
