depth gauge >
depth gauge
depth gauge
Old 05-10-2011 | 09:09 PM
Default depth gauge
The hummingbird unit on the boat is troublesome, it wasn`t working at all, I popped the transducer off put it in a plastic bag with H2O find a place that works. When I cycle the power it stops working in the same place.. its just erratic. I`m tired of messing with it.
I`m buying a new gauge and transducer, should I go with shoot thru puck or transom mount?
My last boat had transom mount and it worked fineas long as it was in the water.
I have no experience with the pucks.
Thank you,
Dan
btw, took the boat out for the first tiome last weekend and I love it!
All the extra room and storage is awesome, the windscreen is functional, the seats are great (no more standing the whole time) it drives like a cadillac compared to the 25' .. etc etc I can`t wait to go out on it again!
Mayden Voyage
ICDEDPPL is offline
Old 05-10-2011 | 09:29 PM
Smitty's Avatar
Buy the one with the puck and mount it inside the engine compartment where Baja made a spot. Clean the area real good and follow the instructions on the install and you will be fine. You do not want a transom mount. It will eventually break off in rough water.
Smitty is offline
Old 05-20-2011 | 07:52 AM
Got a new gauge and the sonar is twice as loud,must have been the gauge, with bilge filled with water it works all the time now, I reused the puck transducer, just have to epoxy it.
ICDEDPPL is offline
Old 05-20-2011 | 09:04 AM
Make sure to get all the old residue/epoxy up..sand the spot real good with sand paper, then epoxy the new puck in.
Bajapred is offline
Old 05-22-2011 | 08:30 PM
I used a rotary bit to clean up all the old crap off the bottom and made a perfect hole then used the the 610 epoxy from a marina and it still gives reading every 5 minutes only.
oh well I gave it the old try, I`m trying the transom mount transducer next.
ICDEDPPL is offline
