Cables
Old 05-14-2011 | 08:31 PM
Default Cables
I installed new trim tab indicator and drive indicator cables on my 27 today. I adjusted the trim tabs almost perfect with the sliding indicators on the dash, but the drive not so well. There is only about 4 to 5 inches of movement in the cables but the drive has a much greater motion than that. I set it so when the dive is all the way down the indicator reads all the way down. When u raise the drive up about half way up the cable is done but there sill is more movement to go up. You really wont drive it much higher than the point where the endicator quits working so i dont think it is a big deal. Does anyone have any insite on this? It this normal? The indicator on the drive is a cylinder that has a rod in it and a spring and it bottoms out on the nuckle of the hydrolic cylinder and that is what pushes the cable.
EarlyInheritance is offline
Old 05-14-2011 | 10:11 PM
Normal yes anything past 7 is pretty much for trailering both fountains i have had done this.
tman is offline
Old 05-15-2011 | 11:46 AM
Thanks i thought that was the case
Old 10-30-2011 | 01:45 PM
Default Cable replacement
While winterzing my 27' Fountain I found that I need a new drive indicator cable. I read your post about replacing yours. Can you remember the information about your replacement cable? Thanks Very Much. BB
blownbucks is offline
Old 10-30-2011 | 04:35 PM
97FASTech's Avatar
Veteran: Army
Default Place to start
here is a link about changing cable and finding right length, and where to get. I actually did mine also, but I went with teleflex extreme cable.
http://www.offshoreonly.com/forums/d...ndicators.html
97FASTech is offline
Old 02-03-2012 | 06:15 PM
My drive indicator cable on my 1994-27 fountain has
"morse 301947-3-216in-6172". Hope this helps someone in the future. BB
Old 02-04-2012 | 01:01 PM
I just called fountain and asked them what length it was, i think i ordered it from them also they were about the same price as everyone else. I am out of town or i could look up the length.
Old 02-04-2012 | 01:04 PM
Seems like it was 17, 19 and 21 and looking at blownbucks part number that looks like 216 might be 21-6in?
Old 02-05-2012 | 10:10 AM
I ordered an 18 foot cable with the thought that 216 inches divided by 12 (12 inches/foot)= 18 feet. BB
Old 02-05-2012 | 12:00 PM
97FASTech's Avatar
Veteran: Army
Looking back on my invoice for the extreme cable part#TEL-CCX63320, it was a 20' cable. This was for 27' FASTech. However my cable thru the hull is on the port side, if that makes a difference.
