Mirage+ or LaserII >
Mirage+ or LaserII
Mirage+ or LaserII
Old 05-29-2002 | 09:13 AM
patrick22309
Default Mirage+ or LaserII
Before I drop $500+ later this week when my Alpha is finished I need a second opinion on prop selection. 89 Stingray (svc200), 3000# Max, 260HP/Alpha 1.50. Was using a 23P QS and it seemed to lug and wouldn't only get 4K-4100RPM WOT @60mph. I was thinking of going to a Mirage+ 21P but they also list the LaserII being good for ALPHAs. Please help me make the $$$ choice.
Old 05-29-2002 | 09:15 AM
patrick22309
Default Additional Info.
The Stingray is the 20ft model.
Old 05-29-2002 | 08:33 PM
Iggy's Avatar
I'm running a 21" Mirage with an Alpha 1.5 and a 350 MAG (270 hp) on a 1988, 20.5 ft Formula F206 LS. Top end is 58 mph @ 4600 rpm.
Factory rep told me I have the wrong prop on it. They found that it came out of the hole better and performed better with a 19" Laser II. Their testing also found that it lost only 2 mph at top end and got better fuel consumption numbers.
I haven't changed props yet, still running the 21" Mirage.
The Laser II looks to have smaller blades (less area) than a Mirage. The Laser also has more rake to it, more bow lift. The Mirage+ is cupped and acts like it's one inch larger in pitch than a regular Mirage.
I was thinking on trying a 21" Laser II to see how it performs.
Unfortunately my funds are low at the moment and I'll have to wait a while.
Let me know what you decide. I'd be curious to know how it works.
Iggy is offline
Old 05-30-2002 | 09:34 AM
Brad Perry
Default This may or may not apply,
But I tried a 27" laser II on a 21' Baja with a small blower motor and could never get it to hook up. You may think that was an extreme situation, but it was happening ALL the time, not just at wot. I could be going 2500rpms and give some throttle and it would just raise rpm and boat would slowly accelerate. It was slipping like mad. A buddy that ran a laser II on his 23' boat and swore by it, tried a mirage and was shocked that he went faster at lower rpms, proving that the laser was in a constant state of slip on his boat. I have been told that the laser is made for smaller (lighter) boats (bass boats..) and does not have enogh blade area for our size boats.
I have progressed through 4 different size mirage props on my boat over the last few years and they have always worked great.
Hope that helps...
Old 05-30-2002 | 09:35 AM
Brad Perry
Default FYI
Marc at BAM MARINE is a great source for props and info of this sort. He's on this board (mbam). Check out his site at go-fast.com.
Old 05-30-2002 | 10:06 AM
EX20's Avatar
What Brad Perry said.
The Laser II is more of an outboard motor prop.
I tried one on my Alpha in a 17ft and it blew out in turns and slipped a lot.
Go with the Mirage Plus 21". More blade area.
EX20 is offline
Old 05-30-2002 | 11:32 AM
Hunter
Patrick, check your PM.
Frankscarab
Prop Talk
5
05-24-2006 11:51 AM
Formula311-SR1
Prop Talk
6
08-26-2005 02:16 PM
klmken
06-18-2002 08:50 AM
Bo Knows
1
03-11-2002 11:15 PM
