best prop for 22' hammer with mild mods?
Got A Carbed 7.4 Ltr In 97 Baja Hammer Thinkn Of Doin Bigger Carb/ Intake An Possibly Msd Ignition To Free Up Sum Exsisting Power/ Create Around 200-400 More Rpms Or So? Running A Nice Surface Peircing Prop That Runs Around 70 Completely Empty.. Wonderin What Would Work Best Maybe For Parts/ Pitch Prop To Get The Most Top Speed Possible With The Mild Bolt Ons? Any Info Would Help.. Thanx A Lot!
There are options. Your current prop model and the actual performance numbers will help make the decision.
Brett
Brett
[email protected]
[email protected]
I don't know what a numbers completely stock propeller is.
When you want to get specific... We're here.
Brett
Brett
[email protected]
[email protected]
i'm guessing you have the mirage plus 23p, had that on my hammer and best i got was 66 maybe 67, added dana marine exhaust and changed to a mirage plus 25p and ran consistent 68 and occasionally a 70 in perfect conditions, exhaust freed up some rpm and could swing the 25p at 4600, 4800 is the top of your rpm band so you could come down alittle
you need a bigger boat for all your babes!
