Spark Plugs And Timing
Old 05-21-2011 | 11:23 PM
Default Spark Plugs And Timing
What Spark Plugs Are You Guys Running On Your Blown 540's And What Timing??
MEDIUMPIMPN is offline
Old 05-22-2011 | 08:34 AM
kind of a loaded question..what blower...cooler ? fuel system ?
ezstriper is offline
Old 05-23-2011 | 07:39 AM
Stock Efi, 4-5 Lbs, M1 Procharger
Old 05-23-2011 | 01:34 PM
hope you have a good retune on the ECM....ac 42 on the plugs, I would get the timing at full advance 26-28..but there is a lot of variables there...from what Ive seen the stock EFI may be a big issure with what you have....I'm running a M3 ona 509, just took off the EFI went to a carb...to much B/S with trying to get the ECM tunied right...some get it right...some don't...if you don't very bad things happen..
Old 05-23-2011 | 08:01 PM
Turbojack's Avatar
What Heads?
You say stock efi, what engine was it stock on? What was HP of engine?
Turbojack is offline
