stewart warner gauges
working on older stewart warner gauges, most gauges I have worked on have 3 connections
ignition 12volt
ground
sender
these gauges only have lugs for 2 connections the ignition and the sender. The ground looks to be picked up by the back bracket which has a copper tab which grounds the casing of the gauge. the 2 lugs are isolated from the bracket and the gauge by a nylon bushing.
does the back bracket pick up the ground from the alum dash plate? I didn't see a lug for a ground on the plate plus someone painted the back of the dash plate?
any thoughts??
ignition 12volt
ground
sender
any thoughts??
Some do use the bracket studs as grounds.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
