Problems w 302 transom?
I was just taking off the crappy Bennett twin ram sport tabs over the w/e to replace with nice 280s K planes when I noticed a bit of water seeping out of one of the lag bolt holes at the bottom after I unscrewed it... I pulled off the cover for the 'thru hull fitting' where they just drilled a damn hole in the transom and shoved a hydraulic line thru it only to notice one of the two lines had not been properly sealed, I would assume from the factory. Lots of black slimy stuff when I stuck my finger in the hole after I pulled the line out. I'm basically figuring I'm screwed, but just wanted to check with the people who know better than I before I pour gasoline on it and have a very expensive barbecue... Anybody know a nifty way to check for water damage in the transom without drilling a bunch of holes?
Thanks in advance.
Thanks in advance.
definately make the drive south and have Kevin at Lakeway in Attica OH fix it but wait a couple of days until he looks at my boat again as i have some transom issues as well and i dont want to big of a line to get mine fixed
www.bajaboatowners.com
unfortunately i think mine might be there this week also i have transom issues as well or should i say more than i already knew about
