bleeding hydraulic rams on bravo one >
Old 05-23-2011 | 12:29 PM
Default bleeding hydraulic rams on bravo one
Do you have to bleed the rams after you remove them? I had one that was bent. I took it off the boat and had it repaired. theres no fluid inside the ram now. was wondering if there was a procedure to reinstall?
pagerboy is offline
Old 05-23-2011 | 12:33 PM
All you should have to do is cycle them a few times and keep an eye on the fluid when trimming up to make sure you dont empty the resirvior.
mr3dman is offline
Old 05-23-2011 | 12:48 PM
Knot 4 Me's Avatar
+1. Had to do this last year after rebuilding a ram.
Knot 4 Me is offline
Old 05-24-2011 | 12:45 PM
+1 here...just did this a couple weeks ago. same process for trim tabs too.
1MOSES1 is offline
