Power Steering Pump compatibility question >
Old 05-24-2011 | 07:38 PM
Default Power Steering Pump compatibility question
Will a MerCruiser power steering pump PN 16792A39 for a 454/502 MPI work in place of a PN 90507A12 for a 350/260 Small Block ?
This is one for the MerCruiser parts experts out there.
Thanks in advance.
sprink58 is offline
Old 05-28-2011 | 05:53 AM
ballon78's Avatar
i looked it up on bammarine.com and came up with the same part numbers.......where did you get the other number??
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 05-28-2011 | 06:15 AM
BAM has 2 different part numbers... a big block part number and a small block part number.
My question is what is the difference in the 2 pumps. I am thinking that yours is the big block pump.
sprink58 is offline
Old 05-28-2011 | 07:31 AM
if there is any question change the pressure relief valve/spring, the big nut under where the high pressure line connects, just take that off, the valve and spring pop right out, swap them and you will have the same as before...you can do the same thing buying a std saginaw pump from a auto parts store...
ezstriper is offline
Old 05-29-2011 | 06:49 AM
ballon78's Avatar
mine is from a big block, thats why i wrote from a 502mpi on the swap shop.....it will work with yours, there all the same.
ballon78 is offline
