stainless marine and takin a big gulp of water >
Old 05-26-2011 | 10:37 AM
Default stainless marine and takin a big gulp of water
So my mechanic just put in my new 454 that I bought here off oso, I also picked up set of stainless marine exhaust manifolds. Mechanic issued a slight warning about taking it real easy coming off plane and also when going in reverse-he thinks the new manifolds sit lower (had an older set of some one offs previously) and is concerned the engine may take a big gulp of water....not so good I'm told. So is there an easy answer and put a taller riser in or should I swap them out for something else. Has anybody else encountered this before. Thanks
paintman is offline
Old 05-26-2011 | 10:49 AM
If the risers line up with the existing exhaust holes, then they don't sit any lower. You should have internal or external flappers on your exhaust tips also to help prevent water intrusion.
Griff is offline
Old 05-26-2011 | 11:15 AM
articfriends's Avatar
mount some exhaust flappers!!!
articfriends is offline
Old 05-26-2011 | 11:18 AM
yep. Exhaust flappers are designed just for that purpose. Any competent marine mechanic should know this.
MILD THUNDER is offline
Old 05-26-2011 | 05:11 PM
ok cool, flappers it is......now i no i can search this but you guys are way faster do they make flappers for turn down style tips
paintman is offline
Old 05-26-2011 | 10:01 PM
No. The turn downs should be connected to the actual exhaust tips and the exhaust tips should have internal flappers.
Griff is offline
Old 05-27-2011 | 04:39 AM
hey griff, im trying to picture the exhaust tips now....and i think the complete tip with turn down is a solid piece, or are the turn downs always an add on?
paintman is offline
