idle issue with ear muffs? >
Old 05-26-2011 | 07:02 PM
Default idle issue with ear muffs?
just started the motors for the first time this year...had the ear muffs on with the water running. at idle the water impellar doesnt seem to be pulling any water. give it a little gas and she starts sucking. is this an issue? i should mention that the water impellar was just replaced a few days ago.
1MOSES1 is offline
Old 05-26-2011 | 07:18 PM
Too Stroked's Avatar
How are you judging that it isn't pumping any water in? Is this the first time the boat was run this season after being winterized?
The reason I ask is that if it's the first time it's been run after being winterized, you've got to let the impeller (Alpha) / raw water pump (Bravo) fill the cooling system before anything comes back out.
Too Stroked is offline
Old 05-26-2011 | 07:23 PM
when the motor is idle i can see the water leaking out of the sides of the ear muffs...when i give it a little gas it starts sucking the water up into the motor (water disappears and stops coming out of the sides)...not sure if this is normal or not.
seems as though their is not enough suction at idle to pickup the water...can someone tell me if that is normal or not.
1MOSES1 is offline
Old 05-26-2011 | 08:04 PM
Did it pump any water out thru the exhaust while it idled?
Powerquest230 is offline
Old 05-26-2011 | 08:21 PM
Most likely the impeller will need to be replaced....how old is it?
SC288 is offline
Old 05-26-2011 | 08:27 PM
wakeywakey
As said before, if water is comming from the exhaust and the temp is normal, it should be ok. Do you have a water pressure gauge and what does it read? How did it behave before winterizing?
It's been awhile since I've used ear muffs, but as I recall it there is always some water running by the muffs, especialy at idle.
A.O. Razor is offline
Old 05-26-2011 | 08:35 PM
I agree. I have the same motors/drives as Moses and it took mine a about 30 seconds to "fill" back up after winterizing. I was nervous as well when I looked at the exhaust and no water was coming out at first.....but it did finally!
If nothing comes out after you wait a bit.....then I'd say the impeller was installed improperly.
Oh Moses...... be sure the front pickup on the Bravo is plugged or it won't suck worth crap. I found that out the hard way...... I just tape them off while I do my flushing....then remove the tape. I have to do this because I don't have the "proper" earmuffs for the dual intake Bravo.
JayFan is offline
Old 05-26-2011 | 08:49 PM
no, none of the water was being sucked up into the exhaust unless i gave it a little throttle. as soon as i gave it a little all of the water was being pulled through.
1MOSES1 is offline
Old 05-26-2011 | 08:50 PM
3 days.
1MOSES1 is offline
Old 05-26-2011 | 08:51 PM
Originally Posted by A.O. Razor
wakeywakey
this is the first time running on muffs. bought the boat last year.
1MOSES1 is offline
