Ground Wire Between Both Motors >
Old 05-31-2011 | 04:33 PM
Craney's Avatar
Default Ground Wire Between Both Motors
Should you have a ground wire run between both motors grounding both motors together?
Craney is offline
Old 05-31-2011 | 04:48 PM
SpeedDoc's Avatar
Charter Member # 302
The battery grounds are doing the same thing. another wouldn't hurt, but probably wouldn't help either.
SpeedDoc is offline
Old 06-01-2011 | 11:09 AM
Steve H's Avatar
artselectricinc.com
A common ground between engines is a must. It should be the same size as your battery cable. I think that it is a CG regulation to do so. It will prevent smoking a small ground wire if you loose the main ground while cranking your engine.
Steve H is offline
Old 06-01-2011 | 11:36 AM
Steve H's Avatar
artselectricinc.com
Found it!
http://law.justia.com/cfr/title33/33...4.9.222.5.html
Steve H is offline
Old 06-02-2011 | 11:10 AM
C_Spray's Avatar
Diamond Member #001
If you have "1-Both-2" battery switches that allow you to power either engine with either battery, you must have a heavy-gauge ground connection between the engines to carry the starter current. That being said, some boats use a grounding/bonding plate where all the battery and engine grounds come together. That will serve the same purpose.
C_Spray is offline
Old 06-02-2011 | 12:56 PM
PhantomChaos's Avatar
Originally Posted by Steve H
Interesting
PhantomChaos is offline
Old 06-02-2011 | 01:18 PM
There's a law for this?
CrownHawg is offline
Old 06-02-2011 | 03:20 PM
Steve H's Avatar
artselectricinc.com
Apparently it is a coast guard reg. Also it is common sense. As I stated in the above post you can melt a wire and potentially start a fire if a main ground is lost during cranking. I own an auto repair shop and have replaced more than one clutch cable because of the above scenario.
Steve H is offline
