K-Planes, post 2004
Old 06-02-2011 | 11:12 AM
Default New K-Planes, post 2004
Does anyone have a newer set of K-Planes, post 2004, with the new bushings mounts who can measure the diameter of the cylinder shaft? I'm in the process of changing over my trim plates from an older set of 150S to newer 280S. Because the cylinder mounts were updated in 2004 and I have post-2004 280S Trim Plates, I either need to buy new cylinders or change the cylinder rods in my existing cylinders. None of the internal seal parts cross over between the old and new cylinders so I'm wondering if they changed the diameter of the cylinder rods.
Post-2004 K-Plane Change
Old Style Mount
RickSE is offline
Old 06-02-2011 | 09:16 PM
O.C.Barry's Avatar
Default Pins / plates
[QUOTE=RickSE;3418525]Does anyone have a newer set of K-Planes, post 2004, with the new bushings mounts who can measure the diameter of the cylinder shaft? I'm in the process of changing over my trim plates from an older set of 150S to newer 280S. Because the cylinder mounts were updated in 2004 and I have post-2004 280S Trim Plates, I either need to buy new cylinders or change the cylinder rods in my existing cylinders. None of the internal seal parts cross over between the old and new cylinders so I'm wondering if they changed the diameter of the cylinder rods.
I'm taking the pins out of my brand new 380's because I am installing the pins with the trim section included. So if you just need the stock new pins, I'll have a new set for sale.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 06-03-2011 | 05:29 AM
Mbam's Avatar
Offshoreonly Advertiser
The piston rod is .750
Mbam is offline
Old 06-03-2011 | 03:02 PM
Thanks O.C.Barry, I have indicators though so I'll need the same pins you're installing.
Mbam, thanks for the number, just what I needed. I've yet to measure my older ones but I believe they're only 1/2" dia., so maybe they did change the cylinders.
RickSE is offline
