Standard time to remove/install 502's >
Old 06-02-2011 | 09:14 PM
Default Standard time to remove/install 502's
I would like to know the standard time to remove and replace a 502 engine from a Fountain. There are 2 of them in the boat!
jbpeterson1 is offline
Old 06-02-2011 | 09:20 PM
When ur compression gets low.
dewayne6243 is offline
Old 06-02-2011 | 09:35 PM
16 hours?
PARADISE ISLAND is offline
Old 06-02-2011 | 10:13 PM
Originally Posted by PARADISE ISLAND
16 hours?
Sounds about right
Old 06-03-2011 | 11:05 AM
Pulling the motors is generally pretty quick...its getting everything disconnectd thats slow and removing the hatch if needed. If yours has the scissor hatch you should be ok. I have never pulled motors on a fountain but have pulled twins on several other boats and it usually takes about 4-6 hours the first time around. First motor is much harder than the second.
FuelinAround is offline
Old 06-03-2011 | 01:10 PM
Fountain4402's Avatar
i woul say a day your first time. It all depends on what kind of lift you got and how many buddies. OTher than that its motor mounts and un-plugging everything. I would figure on a good saturday first time.
Fountain4402 is offline
Old 06-05-2011 | 01:44 AM
If done at a marina Would say 8 hours per engine at most FRL time.
10K4U is offline
